Bleeding a clutch
Old 10-10-2011, 08:23 AM
Kannan08's Avatar
Default Bleeding a clutch
Hey guys, my clutch pedals's spongy as a ****. I thought it was the clutch but it turns out that the clutch need to be bleed. I currently have a jdm b16a with cable trans in a eh2/eg6 hatch. Can you guys help me with a guide on how to bleed the clutch on a cable trans?
Old 10-10-2011, 11:27 AM
apexi_rsx's Avatar
Default Re: Bleeding a clutch
u don't bleed a cable clutch there is no cylinder being pumped with brake fluid to bleed. u have to adjust ur cable by tightening it up with the plastic nut by the clutch arm on the transmission
Old 10-10-2011, 12:39 PM
cvcrcr99's Avatar
LOL. You bleed air from a hydraulic system. You don't have that.
Old 10-10-2011, 12:58 PM
anotherblusi's Avatar
yup tighten up the cable... no hydraulics to bleed
Old 10-10-2011, 01:50 PM
#1 Super Guy
94eg!'s Avatar
Turn the big plastic nut where the cable sleeve attaches on the front of the transmission until it gets snug. Then back it off one click so there is no pressure on the diaphragm.
This is not your trans, but it does show what to look for:
Old 10-13-2011, 10:29 AM
Rayred's Avatar
I am not familure with that model, but some clutches have a cable hydralic combo. Should this be your case you would have a bleed valve at the slave. Blleding Honda clutch systems is tiedious, but pressurizing the tank REALLY helps
Old 10-13-2011, 02:32 PM
92lxsleeper's Avatar
if its in an eg6 like you say, then you have a hydraulic to cable adapter. its just like bleeding brakes.
Ricextacy
01-18-2012 09:12 AM
Kannan08
Transmission & Drivetrain
10-23-2011 11:17 PM
Speed_69
04-21-2006 11:00 AM
InJ3cted
05-24-2005 02:16 PM
GreenMachineRex
05-04-2004 06:22 AM
Quick Reply: Bleeding a clutch
