how to check fuel pressure
My 2006 CRV LX has starting problems yet the battery is new and the alternator tested good. How do I determine if the fuel pump is dying? I do not have engine surges or spluttering, nor loss of power at speed. It is not consistent with the car being hot or cold either.
Moved to proper board...
I seriously doubt it would be a fuel pump.
Hows the maintenance on it? Could be a throttle body is clogged or something in that area from the PCV valve coating it with oil
Are there any check engine lights on?
