ek wit jdm-r problems
Old Nov 11, 2002 | 11:55 AM
jdmrealm's Avatar
New User
Default ek wit jdm-r problems
I have an ek wit a jdm R swap. There is a really big powerdip from about 4k to 6k rpm. Car is running stock jdm ecu, USDM DC header, blitz exhaust. What could this be from?
Also when im in gear above 1500rpm and on the gas, the lights are dim, once I get off the gas, they get bright again. Could this be my alternator or battery?
Could the power dip be related to the lights dimming in any way?
Old Nov 11, 2002 | 12:05 PM
B_CRUZ!'s Avatar
Default Re: ek wit jdm-r problems (ej6)
have you checked your grounds? is there a cel light? have you tried a different ecu?
Old Nov 11, 2002 | 12:10 PM
tonyxcom's Avatar
Cant explain the power dip, do a tune up and check all grounds. Make sure to check your timing as well.
I have the lighting problem you describe though. With my old motor never had this problem, but with the 2000 ITR at lower RPM's the lights are dim-bright-dim-bright and only stay bright once I get over 2500 RPM's or so. Havn't figured it out yet and dont feel like swapping alternators yet.
Old Nov 11, 2002 | 12:43 PM
B_CRUZ!'s Avatar
https://honda-tech.com/zerothread?id=330190
Old Nov 11, 2002 | 01:40 PM
oldB18EF's Avatar
I had the same problems with my lights...what happened was my intake filter was sitting on some wires, which im assuming were for the headlights...when I would get on the gas, they would dim and when not they were normal...i moved my filter and used a new clamp to keep it away from the wires and have not had a problem since
Old Nov 11, 2002 | 01:43 PM
YumVTEC's Avatar
Default Re: ek wit jdm-r problems (tonyxcom)
Heh, me too. Figured my alternator was bad, but it's a 2k ITR alternator with 20k miles on it. Acura probably wouldn't warranty it, though that'd be nice!
Old Nov 11, 2002 | 06:18 PM
ahcjar103's Avatar
Default Re: ek wit jdm-r problems (YumVTEC)
could be from lack of vtec oil pressure from ecu? hmm....i'll look into it more.
Old Nov 12, 2002 | 12:52 AM
jdmrealm's Avatar
New User
Default Re: ek wit jdm-r problems (B_Cruz)
Going to get more grounds tomm. No CEL light. Have tried another JDM itr ecu, same exact thing.
Doing Oil change tomm along with new plugs.
Old Nov 12, 2002 | 04:25 AM
frknfast1's Avatar
Sounds like a timing problem or a Fuel pressure problem. You should get a Hondata with that kind of swap. We sell Hondata at my shop. Call AR Fabrication at (540) 955-2263 between 9am-6pm EST for pricing. Ask for Howard. He'll give you the details. You might just have a nasty fuel hole in one of your maps. Hondata will be able to correct this.
Old Nov 12, 2002 | 10:33 PM
jdmrealm's Avatar
New User
Default Re: ek wit jdm-r problems (ekfour)
Okay now, light dimming aside. Why does it have a power dip? Why is there no vtec "kick"? I can hear vtec engaging ( barely ) but no kick or jump in power.
I changed my oil and spark plugs today. Now im thinking cleaning the fuel injectors? Maybe its from the headers??
Old Nov 12, 2002 | 11:18 PM
tonyxcom's Avatar
Did you adjust valves and timing?
Old Nov 12, 2002 | 11:37 PM
Pho Real's Avatar
Default Re: ek wit jdm-r problems (frknfast1)
HOLY **** YOU PLUGG'N HARD
Old Nov 12, 2002 | 11:43 PM
rc1320's Avatar
Default Re: ek wit jdm-r problems (VTEXTC HB)
a grand will fix most problems, but who has that to just toss out if they dont even have headers man, but ill take two since its such a good deal.....
Old Nov 12, 2002 | 11:57 PM
tonyxcom's Avatar
A new car would fix it too. But that isn't the best option is it?
You DO NOT need hondata with this kind of swap. Not dissing Hondata at all, but your sales tactics are rediculous.
It's like a body shop saying that a new paint job will fix the rock chip on the front bumper. Call Georgy and he will give you all the details and pricing on a new paintjob.
Old Nov 15, 2002 | 01:01 PM
jdmrealm's Avatar
New User
Timing is fine, distributor is fine, grounds are fine ( ima get more added though ). What else could it be? Tried another jdm ecu, same problem. Dirty injectors? I put fuel injector cleaner but it didnt make a difference.
Old Nov 15, 2002 | 01:04 PM
jdmrealm's Avatar
New User
Nope
em1kiddo
May 6, 2011 03:24 AM
red00si12
Nov 30, 2009 11:53 AM
CallmeLuke
Nov 12, 2003 12:19 AM
jdmrealm
26
Feb 26, 2003 01:57 AM
