Skeptical to change ATF fluid 00 accord 2.3 215K
Old Sep 6, 2017 | 10:33 AM
Mason Edmison's Avatar
Default Skeptical to change ATF fluid 00 accord 2.3 215K
Hello,
So, my transmission fluid has not been changed in at least 115K miles. I bought the car at 98K so I can't speak to what service had been done previous. Anyways, I have read that when maintenance is this far passed due on transmission fluid, it can actually put a nail in the coffin of the tranny if you put new fluid in. I pulled the trans fluid dipstick, The fluid on it was red with a brown tinge. From what I can tell the fluid in the tranny is mostly red. Car is shifting Ok but is a little rough.
Thoughts on whether to change it or not?
Pictures:
https://drive.google.com/file/d/0B4D...ew?usp=sharing
Thanks.
Old Sep 6, 2017 | 11:20 AM
nsxmatt's Avatar
Default Re: Skeptical to change ATF fluid 00 accord 2.3 215K
Doing a drain and fill will only change about 3 quarts. Doing that and driving it a while then doing another drain and fill will probably not kill the tranny. A full flush with a machine will most likely kill it.
Old Sep 6, 2017 | 11:29 AM
HonBeer's Avatar
Hehe that is brown. Not red. I am sure it smells burnt.
Old Sep 6, 2017 | 12:08 PM
So you would not change it?
Old Sep 6, 2017 | 12:46 PM
SO you would not change it?
Old Sep 7, 2017 | 09:14 AM
HonBeer's Avatar
Looks overfilled. That would contribute to the burned/brown condition. Yes I would change it. Just drain an refill least twice. Don't use a flush machine.
Tmilli55
Honda CR-V & Element
Sep 26, 2018 01:27 PM
dankoty
11
Jan 8, 2017 03:38 PM
HA0589
Mar 7, 2014 09:09 PM
bmclean1
Feb 24, 2011 08:03 PM
