Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
02 Civic Engine light
Old Sep 5, 2017 | 05:38 AM
phed's Avatar
5 Year Member
Default 02 Civic Engine light
My car is a 2002 Civic. Recently, the engine light turned on. I went to a garage to replace the rear sensor, but the engine light still come up after a couple of days driving. The technician there said I may need to replace the front sensor as well but that is a rare case and not cheap. Any suggestions?
Old Sep 5, 2017 | 10:48 AM
prodjay10's Avatar
Default Re: 02 Civic Engine light
What is the code? Do you know what was replaced? I don't think there is such a thing as a rear sensor.
Old Sep 8, 2017 | 04:22 AM
phed's Avatar
5 Year Member
I did not ask about the code. The technician replaced a sensor that control the emissions between the rear tires.
Old Sep 12, 2017 | 04:51 AM
phed's Avatar
5 Year Member
I asked the code was 1456, any comment?
Old Sep 12, 2017 | 09:04 PM
toyomatt84's Avatar
Sanji
Either a fuel filler cap isn't sealing or a possible leak in the filler neck, could easily be the problem at hand.
Old Sep 13, 2017 | 05:03 AM
phed's Avatar
5 Year Member
Each time after I filled up the gas, I tightened the cap carefully by hearing at least three clicks.
Can the gasket affect it? The technician mentioned that the gasket starts to loose.
Old Sep 13, 2017 | 08:21 PM
toyomatt84's Avatar
Sanji
There's a good video out there on the P1456 code, and the fuel filler neck seal issue.
Old Sep 16, 2017 | 07:32 AM
magog45's Avatar
On a 2002 at this point you might want to look at the vent valve solenoid.
Kodyc
Feb 3, 2017 01:14 PM
tegged
Jul 15, 2016 08:28 AM
90Rexx
Acura TSX
Nov 3, 2012 04:15 AM
hondabinge
Apr 12, 2011 02:13 PM
samuel_gatech
Aug 26, 2006 01:56 PM
