Suspension & Brakes Theory, alignment, spring rates....
97 crv rear bushings
Old Sep 2, 2017 | 02:10 PM
flowerspm15's Avatar
Default 97 crv rear bushings
Hi - we have a 97 CRV with 173,000 miles. 2 years ago the lower control arms and the trailing arm bushings were replaced. Now I have a terrible rattle\clunk in the left rear. If the trailing arm bushings have been replaced as well as the lower control arms, would it stand to reason the issue is with the upper control arm bushings? The rattle happens when we hit some bumps but not others, but it is fairly consistent. It almost sounds like someone left a tire iron bouncing around in the left rear fender or something. I've removed everything from the back - jack, tools, spare, table, etc. to make sure it was nothing loose in the cargo compartment which it is not. Took it to Midas and they said it needed new upper and lower bushings, but that didn't make sense since the lower control arms were replaced in November 2015. I'm thinking about just replacing the upper control arms.
Last edited by flowerspm15; Sep 2, 2017 at 02:14 PM. Reason: additional information
duker733
Jun 11, 2022 07:24 PM
94CivicBTR
Suspension & Brakes
Jul 15, 2013 07:55 AM
SPOOLINmatt
Suspension & Brakes
21
Dec 22, 2010 03:40 PM
jvc7065
Suspension & Brakes
Aug 29, 2007 04:11 PM
Chase Taylor
Apr 7, 2004 04:06 PM
