ecu plug wires
what do you call that wires from the ecu to the shock tower...I do not have the kind of plug with wire between the ecu and the engine harness. Is it ECU plug wire?... normally I guess this the most neglected and ignored portion of those who wanted to pull out the engine and the engine harness. I looked at ebay and I could find one. All I see are the conversion harnesses from OBD2 to OBD1....I dont need it...all I need is the harness of my obd1 from ecu to the engine wiring harness...it should be wires with square plugs for the ecu and on the other end a male cannon plug going out to the engine and connected to the engine harness...
Keri's_baby
13
Dec 20, 2005 04:51 PM
Crxfanatic15
Sep 9, 2003 04:44 AM
