Transmission & Drivetrain Gearboxes, Differentials, Clutches
Clutch/Transmission Issue
Old Aug 30, 2017 | 09:09 AM
JimDCXC's Avatar
Default Clutch/Transmission Issue
I need some help diagnosing a clutch/transmission issue. I've been searching around but am having a hard time finding this same scenario.
I have a 2010 Fit Sport with 102,000 miles and a manual transmission.
I was driving home from work and accelerating from a stop light. After shifting into 2nd or 3rd gear (honestly don't remember) I felt a clunk and then the clutch pedal felt a little stiff so I pulled off of the road into a parking lot to investigate.
The clutch pedal moves up and down although it does feel a little bit stiffer than usual. The shifter is in the neutral position and will not go into any gear with the clutch pedal depressed.
I was able to put the shifter into the reverse position with the engine off and then when I started the engine, the car lurched backwards. The shifter was then stuck in reverse position but after playing with the shifter for a while, with the engine off, I was able to get it back in neutral.
The clutch fluid seems to be at a normal level.
Old Aug 31, 2017 | 09:07 AM
CX-Adam's Avatar
talks to himself
Community Builder
Community Influencer
Default Re: Clutch/Transmission Issue
I was at Jim's place yesterday trying to help him diagnose.
I'm pretty sure it's either a cracked pressure plate, a broken clutch disc spring, or the pilot bearing seized. One of these failures could have caused the loud clunking sound described in the OP.
But, before we tear into it, could a minor internal leak in either the clutch MC or Slave cylinders cause these symptoms? I know how to bleed a clutch system but not how to test the cylinders.
Thoughts?
Old Sep 1, 2017 | 12:14 AM
holmesnmanny's Avatar
be honest, you popped the clutch hard ?
Old Sep 1, 2017 | 06:50 AM
CX-Adam's Avatar
talks to himself
Community Builder
Can confirm. Jim's shifts have never been smooth.
Old Sep 2, 2017 | 08:48 PM
CX-Adam's Avatar
talks to himself
Community Builder
Disc spring blew out. Will post pics later.
Old Sep 3, 2017 | 02:58 PM
CX-Adam's Avatar
talks to himself
Community Builder
Old Sep 3, 2017 | 08:47 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Well, there you go. With a new clutch... problem solved. Way to help a fellow Honda owner out CX-Adam.
Old Sep 6, 2017 | 07:24 AM
JimDCXC's Avatar
Adam is the man. I ordered a new Exedy clutch kit which should arrive today or tomorrow.
Taking everything out was actually a pretty smooth process. The car's not that old but with 102,000 miles I was pretty happy with how clean everything was under the hood and no rusty bolts to speak of. I'm going to try to clean up all the hard to reach areas under the hood while I have access and look forward to getting this thing back together.
Old Sep 7, 2017 | 12:33 PM
CX-Adam's Avatar
talks to himself
Community Builder
"That's one ugly tranny." - Colin
Old Sep 11, 2017 | 05:11 AM
nstyd15b7's Avatar
ahah.. awesome pic, might as well replace the axle seals and if you feel gutzy; do the input shaft seal and bearing.. doing it right now on my ls b18 swap in my eg.
93DA9
Oct 29, 2008 06:06 AM
Simmerman
Jun 23, 2008 05:38 PM
Aralliius
Feb 2, 2008 12:18 AM
doood
Aug 21, 2007 06:57 PM
pho iz good
Jul 21, 2007 02:51 PM
