AFR drop while WOT at 7500 rpm
Old Aug 26, 2017 | 10:41 AM
Daffy_ed9's Avatar
Default AFR drop while WOT at 7500 rpm
Hey gents,
I´m currently tuning my B20Vtec with BRE.
Car is running absolutely good so far, except there is an AFR drop from 12 to 14 happening in a short time frame somewhere around 7500rpm.
When we found out that this seems to be full related, I gapped down my spark plugs and installed a new Walbro fuel pump.
AFR at WOT is 12, except the above mentioned rpms.
Any suggestions or hints what I should look at?
Specs:
B20VTEC
13:1 compression
Denso Iridium B18C6 spark plugs gapped down
Wahlbüro 255l fuel pump
H22 injectors running at 12ms on WOT
Thanks in advance from Germany
Old Aug 26, 2017 | 01:53 PM
1HGEJ2's Avatar
Default Re: AFR drop while WOT at 7500 rpm
Hallo daffy
Warum verkleinert ihr den elektrodenabstand? Bei Verdichtungheraufsetzung vergrößert man eigentlich den Abstand. Mit was wird abgestimmt?
Old Aug 26, 2017 | 02:21 PM
2x0's Avatar
2x0
10 Year Member
So you are tuning, and I assume have tried increasing fuel at the problem rpm and it still has an increase in AFR?
What is your injector duty cycle at when this happens? If that's not an issue try hooking up a fuel pressure gauge to the rail and watch what happens when the AFR rises.
Old Aug 27, 2017 | 09:38 AM
Daffy_ed9's Avatar
Originally Posted by 1HGEJ2
Hallo daffy
Nein, bei Verdichtungserhöhung wird der Spalt verkleinert.
Bre, steht im Text
Old Aug 27, 2017 | 09:39 AM
Daffy_ed9's Avatar
Bre, steht im Text
@2x0
Duty cycle is somewhere around 11 with my 345cc injectors.
Will install a gauge for checking fuel pressure
Old Aug 27, 2017 | 12:36 PM
1HGEJ2's Avatar
Bre, steht im Text
was ist bre?
Bei turboaufgeladenen Motoren wird der elektrodenabstand verkleinert und bei Motoren mit erhöhter Kompression vergrößert. Dadurch hat der zündfunken mehr Stärke und Energie.
Old Aug 28, 2017 | 04:16 AM
Daffy_ed9's Avatar
Bre is a tool for Tuning OBD0 cars.
And again, you Need to REDUCE the gap for FI and high comp cars. ( The reason for that is, that because of FI or high comp the spark can be blown out during Operation.
Increasing the gap reduces the spark power, because the way it Needs to pass is longer.
And if you read the diagram you posted in, ou will see that it is a fault from translating Inch into mm.
BEcause the incha values given Show, that you Need to REDUCE the gap. Only the mm values are messed up
Information from NGK:
Another consideration that should be taken into account is the extent of any modifications that you may have made to the engine. As an example, when you raise compression or add forced induction (a turbo system, nitrous or supercharger kit) you must reduce the gap (about .004" for every 50 hp you add). However, when you add a high power ignition system (such as those offered by MSD, Crane, Nology) you can open the gap from .002-.005".
Old Aug 28, 2017 | 08:25 AM
Roy Leyva's Avatar
Remove or change fuel filter and put an adjustable fpr to raise pressure to 50psi at idle, that solve the problem.
Old Aug 29, 2017 | 12:15 AM
1HGEJ2's Avatar
yeah ive read only the mm measurements. ure right
akinas-crx
Engine Management and Tuning
Nov 13, 2011 06:52 PM
k24killer
Aug 22, 2008 11:26 AM
AW
Jun 3, 2006 10:40 AM
MysteryWagon
10
Jul 25, 2003 08:30 AM
KoRE
Jun 18, 2002 11:42 PM
