b20vtec or h2b
Old Aug 24, 2017 | 01:30 PM
fatdudeinaef's Avatar
Default b20vtec or h2b
I just bought a ls swapped 91 hatch tryin to decide between buiding a b20 vtec or doin an h2b with a h22a and just cams intake exhaust and tune whats yalls opinions
Old Aug 24, 2017 | 05:12 PM
ontariorider's Avatar
Default Re: b20vtec or h2b
b20vtec
Old Aug 24, 2017 | 10:03 PM
Can I ask why
Old Aug 25, 2017 | 04:01 AM
browngrasscat's Avatar
Why not go vtec on the LS?
Old Aug 25, 2017 | 04:37 AM
Chance EG's Avatar
Because B20 has more bore/displacement.
In the EF chassis I would definitely recommend B series over H2B. Space is very limited.
Old Aug 25, 2017 | 04:56 PM
I'm aware, but this seems like a relatively casual build, I'm assuming b20+vtec and done.
the extra 0.2 liters probably won't register on the butt dyno anymore than a decent header on the b18 would for the same pri've and less work.
Old Aug 25, 2017 | 06:35 PM
Chance EG's Avatar
How would an LS VTEC be any less work or cash?
Old Aug 27, 2017 | 03:06 AM
He already has the B18 (less cash) it's already in the car (less work) "LS swapped 91 hatch" in 1st post.
Being that the car already had a decent bottom and (there's no mention of blowing it up yet) and a Vtec swap doesn't require pulling the engine, it's just 1 less step.
Old Aug 28, 2017 | 07:25 PM
i hear the lsvtec and b20vtecs aren't as reliable and its street/strip build I know the h22a has shitty cylinder walls but they seem to make incredible torque and ive seen a few bolt on h22s lay down over 200whp
Old Aug 28, 2017 | 08:05 PM
Chance EG's Avatar
110% incorrect.
Old Aug 28, 2017 | 09:00 PM
Evo9GSR's Avatar
Well H2B is gonna be more expensive. LSV is a great motor set up and B20V is even better. Going H in an ef is almost like going k. A lot of extra steps need to be taken. Plus it's gonna be a process getting your stock hood closed. Oh yea and whoever told you LS or B20 Vtecs aren't reliable lied to you.
Old Aug 29, 2017 | 03:28 AM
Anything can be unreliable with cheap parts or bad work.
Old Aug 29, 2017 | 06:18 AM
sont ls motors blow up soon after addin vetch due to reving higher than it shoulda ever reved
Old Aug 29, 2017 | 08:51 AM
wll from what ive priced its gonna cost about the same and the h will prolly make more power and I got ef h motor mounts already and my hboy has an h2b trac bar
Old Sep 3, 2017 | 05:06 PM
just gonna turbo the ls and build a h22 while I'm drivin it
prjdmek
Mar 10, 2010 09:24 AM
bui1528
Aug 27, 2009 12:24 PM
barnie
Jan 12, 2009 12:50 PM
canospeed200
May 5, 2008 04:14 PM
90scrx
Dec 8, 2004 12:28 PM
