Del Sol rear disc compatibility
Hey all, still a bit of a noob here, just trying to figure out whether rear discs from a JDM 93 del sol si will swap over to my 91 dx hatch. Been reading tons about rear disc swaps from tegs and ex sedans, but I straight up cannot figure out if the del sol rear trailing arms will swap over. Or if I can just swap over the spindles? Still a little shaky on the forum manners and stuff, let me know if this has already been covered somewhere.
Re: Del Sol rear disc compatibility
yes, all trailing arm stampings are the same, then there is a cast knuckle that bolts to the trailing arm stamping. the cast knuckle is what determines drum or disk. however, that's a bastid to get off, so I just swap entire TA assemblies out and call it a day.
AFAIK the CRX is the only direct fit replacement. All other TA's change the track width of the car. I have measured a CRX and DC integra and can confirm that the mounting points are different. I haven't measured the DA or Del Sol ones yet.
All TA stampings MIGHT be the same, but not all TA's are the same.
zombieD
04-17-2010 04:41 AM
