only starts if I pop the clutch
Old Aug 24, 2017 | 07:57 AM
Eeness's Avatar
Default only starts if I pop the clutch
1999 honda civic ex 5 speed. it drove fine then one day it wouldn't start. I bought a new starter and it still didn't start. I checked the battery, and the connections and it still won't start. Any ideas?
Old Aug 24, 2017 | 09:19 AM
2x0's Avatar
2x0
10 Year Member
Default Re: only starts if I pop the clutch
Does the fuel pump prime when you turn the key on?
Does it click or do anything when you try to start it?
Old Aug 24, 2017 | 09:45 AM
civic402lx's Avatar
Check the clutch safety switch, the plastic piece.
Old Aug 28, 2017 | 07:43 AM
Eeness's Avatar
It was the Clutch Safety switch! thank you both for the help!!!!!!
Old Aug 30, 2017 | 03:05 AM
NVturbo's Avatar
O.G. triple O.G.
Had the same issue yesterday. Luckily, mine was the damn plastic piece (AKA clutch/brake pedal stop pad).
Old Aug 31, 2017 | 04:51 PM
crazyhorse2011's Avatar
10 Year Member
Loved
you could always short out that switch and move it elsewhere....
my 95 will start in gear. although this seems dangerous I just check my gear before hitting the key, a good habit to be in. In the event that my engine were to fail at a stoplight I would be able to use the starter motor to safely move the car off the road (albeit jerky and possibly at the expense of the battery or starter, nevertheless its a good backup if I were in a dangerous situation and needed to move on command)
In fact, I actually had a 88 CRX at one point. It was struggling with a pretty bad TPS issue. The car would run fine for days then suddenly act like the ECU was ripped out of the car, put the pedal to the floor and the engine would die at any speed, at a stoplight, without any warning whatsoever. One day it did this right near my house and I was so close to home, I used the starter to move the car off the road safely. If I didn't have that ability it would have been me pushing the ****** the rest of the way like an idiot.
moparguy
Sep 22, 2015 03:33 PM
gustafse
Nov 27, 2011 04:55 PM
Ecskater1313
13
Oct 27, 2008 08:00 PM
fullboostin
Jan 4, 2008 03:49 PM
jerBEAR
Oct 31, 2005 10:34 AM
