obd2a motor, obd2b harness, obd1 ecu
Old Aug 21, 2017 | 02:10 PM
jspinelli8's Avatar
Default obd2a motor, obd2b harness, obd1 ecu
I have a 99 b18b that i'm putting into a 2000 civic ex. The problem is that the motor is obd2a but the civic harness is obd2b. Will the harness work with this motor and if not what should i do? maybe get a harness out of a 96-98 civic ex?
Old Aug 22, 2017 | 01:08 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: obd2a motor, obd2b harness, obd1 ecu
Use your EX harness and make the neccesary adaptions:
-obd2b-a distributor adapter
-CKF connector swap
Old Aug 23, 2017 | 04:00 PM
jspinelli8's Avatar
-CKF connector swap
Thanks, so this is all i'll need to do to make it work?
untraceable
Dec 10, 2009 07:08 PM
bokals
Oct 22, 2009 12:54 PM
D3U1LT
Jan 24, 2005 10:47 AM
Charlie Moua
Sep 25, 2003 04:19 AM
alltech
May 18, 2002 10:28 AM
