P28 virgin limp mode Fixxing
Old Aug 20, 2017 | 03:44 PM
adrian_crx's Avatar
Default P28 virgin limp mode Fixxing
Hello guys.
Im having issues with a p28 virgin,
First i changed the TA8903SN, (the first run in the morning, tooks up to 5 minutos to send the signal to the main relay)
Now that works fine, BUT, there is always something, now its in limp mode, it cuts the rpm between 3500 and 4000 rpm.
I cannot find anything on google about which component is the one that control's the limp mode. (with the old ta8903sn that didnt happend)
Any help will be excelent,
PS I tested the car it with another p28 and there is no problem on the car, so there must be something else burn in the ecu.
Old Aug 23, 2017 | 05:14 PM
bulito's Avatar
Default Re: P28 virgin limp mode Fixxing
are the electrolytic capacitors ok? if not try changing all it. I think there are 6 electrolytic capacitors.
Old Aug 24, 2017 | 11:18 AM
v4lu3s's Avatar
RTFM
I have several p06 and p28 ecu's that take 3-10 minutes to prime the fuel pump and fire, and as best I can determine there is a problem in the injector circuits on the board, and basically i just saved them for parts if i need, and the warmer and more humid it is the worse it gets. What you are dealing with sounds similar...
theidealone
Jul 1, 2010 10:43 PM
theidealone
Jun 25, 2010 02:21 PM
tai_mishuu911
Oct 13, 2009 07:02 AM
Vic Nyce
Apr 3, 2003 03:42 PM
