CV replacement nightmare.
Old Aug 20, 2017 | 03:44 PM
dumbidea's Avatar
Default CV replacement nightmare.
I did the ole between the fork method for the CV joint replacement. Passenger side of a 99 v6. Got the CV joint in and seated and the lower control arm is about 2 inches away from aligning with the wishbone for the throughbolt. So the wishbone is LOWER than the control arm. Problem seems to be I cannot raise the shock and therefore the wishbone without pulling it out and the axle from the transmission with it.
How do I raise the shock (compress it) so that the fork aligns? It's so far low I can't raise the hub assembly to get the lower ball joint into the lower control arm.
The spring doesn't apprear to the the issue. Is it?
Old Aug 20, 2017 | 04:33 PM
holmesnmanny's Avatar
Default Re: CV replacement nightmare.
can you get a second person to push down on the rotor with their foot ?
im hoping the cv joint did pop out of the joint
Old Aug 20, 2017 | 04:39 PM
dumbidea's Avatar
Some reason I can't upload an image. I'll fix that tomorrow. I should have included pictures. They really help explain everything. I'll update later. But essentially, I need the rotor raised. But the axle is hitting the top of the wishbone which won't raise so I could attach the lower ball joint back.
Old Aug 20, 2017 | 07:52 PM
I remember in situations like these I had to remove the two bolts holding the radius rod to the lower arm but you might want to try just removing the fork and putting the ball joint in and then setting the fork back in, I think in that situation you should be able to just push down on the rotor and get the fork bolt in
xChrizcrozzx
38
Dec 9, 2016 10:34 AM
tree fingers
Feb 18, 2008 10:41 PM
Vp Special K
17
Jan 6, 2004 02:08 PM
97ex+zex
Jan 28, 2003 04:36 PM
XEF-9X
18
Aug 15, 2002 10:31 PM
