WTB B18 Flywheel, D16 Cold Air Intake, CRX Exhaust, Flywheel Bolts, Crank Pulley Keyw
I have what I believe is a 1994 B18a1 Y1 cable trans and I'm looking for a flywheel. Need at very least the flywheel, would take a whole cheap clutch kit. Need a clutch tool as well. Also need a cold air intake for my CRX B swap, any d16 should work fine I believe eBay parts are fine need piping and filter. Also could use a cheap CRX full exhaust including test pipe if I can't find one I'll grab one on eBay and swap out the muffler. Also need flywheel bolts for my Y1 trans, as well as the mounts that go from the trans to the block and I need the keyway for the crank pulley. Also looking for shift linkage for CRX b swap. Need parts ASAP almost ready to swap motor is already pulled just thought I'd try on here before ordering on ebay
Also need an ECU I bought one but accidentally bought an automatic. Need an OBD1 manual for a B18a1
i have a lightweight aluminum flywheel, flywheel bolts, pressure plate bolts and crank pulley key. Inbox if interested, can send pics via pm or text.
Hi I have a D16 AEM Cold Air Intake with a new Spectre filter i'd let go for $65 plus shipping. I'd include the boot and clamps as well. PM me if interested
