Quick question about IMA sensor.
Old Aug 13, 2017 | 01:26 AM
antonio1122's Avatar
Default Quick question about IMA sensor.
I had CEL 11 ever since swap is done, I simply couldnt be bothered with it. However, DOHC ZC with no cat obviously, ECU is looking for IMA sensor. How important is it to have it, does it adjust fuel trim in any shape or form? I can easily source one but just wondering what the hell it does in the first place? I know what O2 sensors do, they adjust everything based on fuel in exhaust chamber, or I got that wrong too? Thanks.
Old Aug 13, 2017 | 01:34 PM
civic402lx's Avatar
Default Re: Quick question about IMA sensor.
You should search better.
https://honda-tech.com/forums/honda-...-11-a-3039965/
Old Aug 13, 2017 | 02:00 PM
Originally Posted by civic402lx
Doesnt really tell me anything, its for emissions only? I hardly doubt thats his only function, all I'm wondering is that sensor has anything to do with fuel injected at any given time, e.g. different idle with/without one. Saying sensor controls emissions is vague as hell, I'm asking because I obviously dont know, so constructive reply from someone who knows its function would be appreciated, and by function, a real full explained function not just a single word cause Google gives no results whatsoever.
Old Aug 13, 2017 | 05:45 PM
civic402lx's Avatar
Base off that thread, your ecu is looking for it for emission purpose. But cant findthe sensor, the sensor use o2 to measure fuel mixture. For states that required emission like, california among others, will determine if you can get your tag renew or not. Pass then yes. Since you arent as concern with emission then find an appropriate ecu which does not look for the sensor then you will be fine. How much i depth are you trying to look into the ima and emission? Apparently ecu swap is the easiest remedy. Assuming you can find one. Or buy the sensor and wire it up.
Old Aug 13, 2017 | 10:04 PM
Which essentially means it adjusts fuel/air based on readings hence does affect vehicle performance and how it runs? Thats what I'm concerned about though.
Old Aug 14, 2017 | 05:18 AM
civic402lx's Avatar
So buy and install the sensor or find an ecu that does not use the sensor. Or get a chipped ecu with a map that does not use the sensor. Then you will be fine. Performance will be good.
Old Aug 14, 2017 | 06:14 AM
I already have wiring but dont have sensor though, its 4 pin which extends to header. Does it go on header directly or down below. I have 4-2-1 aftermarket header and I can either mount it on one of 4 on headers, or down where it goes from 2 to 1.
So yes it affects performance? Basically my car will run better with that sensor?
Old Aug 14, 2017 | 01:45 PM
civic402lx's Avatar
It will have minimal on performance. It will run more efficient, like it supposed to run from factory.
Old Aug 15, 2017 | 01:09 AM
Is IMA sensor basically an o2 sensor on modern cars? When I look to buy a new IMA sensor I get "O2 sensor blabla IMA sensor Civic etc". Anyone has part number? I see all o2 sensor has that square 4pin connector just like mine has ... I'm confused not sure what to buy ...
Old Aug 15, 2017 | 05:12 AM
civic402lx's Avatar
What year make model your car?
Old Aug 15, 2017 | 05:26 AM
1992 honda del sol with a DOHC ZC swap.
Old Aug 15, 2017 | 08:02 AM
CandyRedRC46's Avatar
Holy spoon feed batman.
Old Aug 15, 2017 | 09:06 AM
Dafuq?
Old Aug 15, 2017 | 08:31 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Take a look at this:
https://www.3geez.com/forum/efi-tech...nsor-help.html
If you are still stuck... how about running a USDM '94-95 P74/P75 ECU and installing a 4-wire O2 sensor and move on.
Old Aug 16, 2017 | 09:19 AM
civic402lx's Avatar
All info posted can be found searching the net. But some how you still cant find it. I already send you a link in pm. You can try that. If you still want to run ima sensor. Frankly, its less work to get a chipped ecu that will not look for the sensor. Or convert it to O2 sensor like what he said above. Or find pm7 ecu that does not seek the ima sensor.
Old Aug 16, 2017 | 10:09 AM
{ S P O O N F E E D I N G I N T E N S I F I E S }
Jwbetley
Engine Management and Tuning
Nov 15, 2008 04:44 PM
rasta420
Jun 8, 2007 01:59 PM
Mr.Death
Jun 27, 2005 09:01 PM
Hyaboosta
Apr 22, 2005 12:04 PM
