water pump
Old Aug 9, 2017 | 03:16 PM
miketines's Avatar
Default water pump
is my water pump the leak or is it a crack in block
Old Aug 11, 2017 | 03:09 PM
DumpdEJ6's Avatar
I like the tuna here
Default Re: water pump
Water pump. Well, maybe the block. Heck, probably both.
Old Aug 11, 2017 | 03:47 PM
Nave43's Avatar
Read the rules, and update the tread with more information and you may get some help.
Old Aug 11, 2017 | 05:06 PM
tamboo's Avatar
10 Year Member
get a made in japan water pump and tensioner.
gates is now made in china so do not buy.
i'm running npw brand, seems like good quality but only time will tell.
koyo tensioner as well.
https://honda-tech.com/forums/honda-...civic-3114911/
Old Aug 13, 2017 | 06:11 PM
settimi's Avatar
If you are getting a new water pump get a genuine Honda. Much better quality and less likely to go out.
Old Aug 14, 2017 | 03:13 AM
NVturbo's Avatar
O.G. triple O.G.
You can find Genuine Honda water pumps, tensioner and timing belt for the same price as those "OEM" parts. Just have to look.
Old Aug 14, 2017 | 08:40 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
I am aware of alternative sources for the OE tensioner and timing belt without paying the "Honda box" premium in price... but I haven't been able to source "Yamada" brand oil and water pumps. Since you happen to be on the "Inside"... maybe you could share an alternative source for these products with the H/T community ???
Old Aug 15, 2017 | 02:22 AM
NVturbo's Avatar
O.G. triple O.G.
here you go. It's just a random search for a 1997 Honda Del Sol SI. Yamada water pump.....
https://www.hondapartscheap.com/auto...stat-s-si-scat
Egpower88
Feb 6, 2009 06:30 PM
yaaj1320
Mar 3, 2007 08:53 PM
808State
Apr 8, 2004 12:22 AM
