Won't go over 3,000 RPMs
Old Aug 8, 2017 | 05:21 PM
Shugars69's Avatar
Default Won't go over 3,000 RPMs
What would cause my 2002 Honda Accord not to go over 3000 RPMs weather is in drive or neutral
Old Aug 8, 2017 | 11:31 PM
Jonah Klepp's Avatar
Default Re: Won't go over 3,000 RPMs
Is the car coding? That would be one of the easiest ways to find out the issue. It sounds like the car is in limp mode.
Old Aug 9, 2017 | 11:14 AM
MAD_MIKE's Avatar
MM Gruppe B
Check your oil level.
Check for any oil leaks around the VTEC solenoid.
Verify there are no stored codes.
Old Aug 17, 2017 | 02:30 PM
shahmeer.alpha1's Avatar
There's a problem with the crank sensor. There's water inside it. There'll bd fuel cut on 3000 rpm. As soon as the sensor dries, it'll be perfect.
Old Aug 17, 2017 | 02:31 PM
Be*.
I had the same problem. Usually happens due to heavy rain or if you get the engine bay cleaned. Happens very less.
Bj Bennett
Honda Civic (2001 - 2005)
Dec 16, 2015 04:31 AM
mujjackson
Dec 13, 2013 04:22 PM
Major90
Dec 18, 2009 07:36 AM
Superman137
Jun 12, 2005 04:50 AM
FREAKquency04
Oct 20, 2003 08:53 AM
