Fuel injectors
Old Jul 31, 2017 | 10:22 PM
racin97's Avatar
Default Fuel injectors
sorry if im posting this in the wrong place. I race oval track i run an f22a1. Obviously, i have the low impedence injectors. I decided to buy a stand alone harness so i could do away with a lot of unused wiring. I asked for the plug for the resistor box to be wired in but they didn't do it. My question is (as long as the connector will fit injector, can i run f23a1 injectors without the resistor box and be ok? Or do i need to just go ahead and wire it into the harness? Thanks
Old Aug 1, 2017 | 12:00 AM
holmesnmanny's Avatar
Default Re: Fuel injectors
I'm not going to speak for if the f23a1 injectors will work in terms of the build, but f23a1 injectors themselves don't use a resistor box so you won't need one for them
Old Aug 1, 2017 | 05:34 PM
racin97's Avatar
I know they will fit in each others fuel rail so sounds like i should be alright doing that then. Thanks for replying.
Evansouders
Jul 30, 2013 05:50 PM
Steeve_Civic
Dec 4, 2011 10:11 AM
DrivinVtec
Sep 17, 2007 10:08 AM
tarheelsoldier
Jan 10, 2007 08:13 PM
ridnmyhonda
Mar 18, 2003 06:24 AM
