B20vtec in 95 eg hatch WON'T START!! HELP PLEASE
Old Jul 27, 2017 | 03:10 PM
Ross Loonam's Avatar
Default B20vtec in 95 eg hatch WON'T START!! HELP PLEASE
OK so spec of the car atm is
its a 1995 honda civic eg hatch
b20z1 block completely stock
1.8type r head
type r cams
b16 inlet manifold
Y21 gear box
the car was previously a 1.3 dual carb it's got totally gutted all interior and exterior got a full inside wire loom including dash loom clocks with revs and a p30 ecu Fuel tank fuel lines and fuel pump were installed
I have the motor in and it swings over but won't start
it has fuel spark all grounds are on gear box rocker cover and water housing ground the relay under the dash is working cause I have 3 of them
the compression is
No.1 200
No.2 188
No.3 180
No.4 195
the clocks display is only displaying a oil light
there are no other lights coming on the clocks I can't get a engine management light to come on and can't read any codes to problem solve did any body every come across anything light this??
could this be my ecu or what is the problem??
Old Jul 27, 2017 | 03:46 PM
tony_2018's Avatar
Fish Twig
Default Re: B20vtec in 95 eg hatch WON'T START!! HELP PLEASE
1.8type r head
type r cams
b16 inlet manifold
Y21 gear box
the compression is
No.1 200
No.2 188
No.3 180
No.4 195
No honda civic I've seen has ever had a clock display show an oil light.
Old Jul 27, 2017 | 05:10 PM
crazyhorse2011's Avatar
10 Year Member
Loved
clean all grounds with sandpaper
check underhood fuse block for blown fuses, especially the ECU fuse
if not swap in a known good computer and go from there
Old Jul 28, 2017 | 07:57 AM
This is the light im talking about and is the only one on display? Goes off after cranking the engine a couple of times
now all grounds are good been check about 3 times now and cleaned all the fuses are good been checked about 3 times now aswell it must be computer?? Or could it be something else?
Old Jul 28, 2017 | 08:24 AM
You never seen this light on the dash of a Civic?
I checked all grounds fuses and cleaned them all about 3times now there fine it must be computer or is there anything else I can try?
Tim Larkin
Jan 19, 2016 01:42 PM
Eg-Jav
Jan 3, 2013 11:49 AM
oopcyan4shoo
Jun 7, 2012 05:07 PM
Slacker93eg
May 5, 2012 06:18 AM
Beckerton
Feb 21, 2011 05:08 PM
