Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Electrical system charging issues
Old Jul 27, 2017 | 01:17 PM
thatseemslegit's Avatar
Default Electrical system charging issues
My girlfriend has a 2012 civic lx, auto 4dr. She has been having issues the past few days with not being able to start her car. After sitting for 4 hours, not enough power to turn the starter (relay clicking). Jump the car and it's fine. Tested the battery at Autozone and they said its fine. They tested the alternator and said it might need to be replaced. I'm not so inclined to believe him tho, he tested it right at startup and it seems the varying loads on the system changes the alternator output. I know this year has an electronic load detector that controls the alternator output. I'm not sure what the threshold of normal is however. During low load, voltage sits at 12.6. Under high load (lights on) the voltage sits at 14.3~5. Is this normal margins? Drove the car home with lights on, and after letting it sit for 2 hours the voltage was at 12.8v and no parasitic power draws.
Old Jul 27, 2017 | 03:47 PM
holmesnmanny's Avatar
Default Re: Electrical system charging issues
Yes, those numbers are fairly normal. How many miles ? It's possible somehow the starter is already going out. Autos tend to have the inferior starters.
Old Jul 27, 2017 | 04:06 PM
60k miles. It doesn't seem like a bad starter. Dim lights, pulses with the starter relay clicks.sounds like low voltage to me. I wish I had a multimeter when I had the car at a no start condition. I'm thinking now a possible bad ground somewhere, causing intermittent charging.
Old Jul 27, 2017 | 09:55 PM
you did an actual parasitic draw test ?
i would say less than 1 percent chance of an issue with the alternator itself
Old Jul 30, 2017 | 01:56 PM
RiPe14yoU's Avatar
If you had charging issues in the vehicle then the battery light would come on especially if it's under charging. Would look at starter or possibly bad transmission/engine to chassis grounds.
Old Sep 4, 2017 | 12:49 AM
Cleaned all grounds and it has not happened again, crossing my fingers that that is the only problem
Bigmo5328
May 4, 2015 10:06 AM
duyfash0
Jul 1, 2007 05:22 PM
NFM_Dm
Oct 30, 2004 06:08 PM
iTR.EX
Jan 21, 2003 07:16 AM
