Car won't start after running perfectly the night before
Just had my car dyno tuned and everything was working great.
Drove home last night and car was perfect.
Tried to start it this morning and it will crank but won't start.
It will try for a half second but won't fire up at all.
From the top.
Car cranks but doesn't start.
Verified that it has fuel and spark.
Figured spark was weak so replaced coil with one that I knew worked.
Still didn't start.
Replaced distributor with another used one.
Also verified mechanical timing didn't skip any teeth. Replaced rotor and cap with OEM honda parts.
Still didn't start.
Checked all grounds and pulled plugs to let cylinders evaporate excess fuel overnight (possible flooding)
Replaced plugs with new plugs. Still didn't start.
Neptune RTP is datalogging rpm and map sensor is reading correct values.
Any input is greatly appreciated. I'm out of ideas other than possible wiring issue or icm in distributor.
Thank you!
From the top.
Still didn't start.
Still didn't start.
Thank you!
adhd316
Honda CR-V & Element
Feb 6, 2014 03:21 AM
dan89crxsi
Feb 10, 2007 02:44 PM
chinese buffet
Jul 16, 2006 05:09 AM
