Front axle replacement
Old Jul 23, 2017 | 07:28 AM
Sean1988's Avatar
Default Front axle replacement
How hard is it to replace from axle on a 96 honda accord what tools do I need. Was burned by my normal shop 300 dollars and will never return there and this is going to be my first project on this car
Old Jul 23, 2017 | 10:39 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Front axle replacement
Rockauto, order up a new axle. I have had no problem with Cardone Select.
Follow the instructions in the FAQ at the top of the forum on how to pop hte lower BJ easily.
Hardest part is breaking the stub axle nut free.
Disconnect the sway bar endlink.
Use the technique on how to pop the lower BJ. Careful with the boot.
You will not need to separate the shock/coilover 'fork' from the lower control arm.
Keep the plastic wrap/bag on the axle while installing it(or put one on the end). This will protect the boots, especially the inner one when sliding it through the aforementioned fork.
When putting the inner stub axle into the transmission, carefully guide it past the oil seal. Splines on the inner stub can slice the seal, or if you pop out the garter spring(keeps tension on the seal) you will end up with a massive oil/atf leak.
I've changed out axles in ~15mins, just be aware and careful.
Old Jul 23, 2017 | 11:45 PM
holmesnmanny's Avatar
The best way is to put an allen wrench inside of the caliper where it meets the brake rotor fins with the car in neutral. That will lock the hub in place, preventing the need for someone to hold the brakes.
Old Aug 7, 2017 | 02:57 AM
Sean1988's Avatar
What size socket do I need to get the axle nut off
Old Aug 7, 2017 | 08:20 AM
angrysmileyface's Avatar
36MM
grjr
Aug 23, 2012 04:12 PM
Corksil
Nov 23, 2009 01:30 PM
sleepinbeauTEG
Jan 21, 2005 08:37 AM
Laurence
Jun 5, 2004 01:20 PM
S.Celia
Jan 26, 2004 07:24 AM
