Brake booster question
I have a vacuum leak where the master cylinder flange bolts to the brake booster. Is there some kind of gasket/seal in between the two that I can replace to stop the leak? If so what is it called or part number? Could something else inside have failed causing this? Should I replace the entire thing?
I attached a picture of the seal I think I need. (Hope the attachment works) It is part number 46185SE0003. Found it on ebay. Can anyone confirm that this seal will stop the vacuum leak? Car is a 2004 Honda civic ex. Any help is appreciated.
Edit: This seal solved my problem. It is the Master Cylinder rod seal
Markb16a
13
Apr 13, 2010 11:25 AM
caliskier
Jul 15, 2009 08:49 PM
dxhatch92
Jan 16, 2007 08:13 PM
