Stripped AC high port shrader valve
Old Jul 20, 2017 | 04:49 PM
dgdarien's Avatar
Default Stripped AC high port shrader valve
I was servicing the AC system and replaced the shrader valves inside both ports of the AC. But while installing the high port shrader valve; I tightened it too tight with the tool and broke the little metal pieces the tool uses to hold/grip onto the valve. So it seems pretty stuck in there; I do not really wish to deal with trying to remove it, because I've heard it is either really difficult or involves replacing the whole pipe/tube.
The system was vacuumed and no leaks detected and holds pressure.
Would it be okay to just leave it as is; and recharge the system?
Old Jul 20, 2017 | 06:44 PM
tony_2018's Avatar
Fish Twig
Default Re: Stripped AC high port shrader valve
So you replaced valves and pulled a vacuum even though you knew there were broken pieces of metal in the system?
Old Jul 20, 2017 | 06:47 PM
Chance EG's Avatar
I guess you might as well since you've already pulled vacuum on it... Kinda past the point of no return now I think.
Old Jul 20, 2017 | 07:16 PM
fragmare's Avatar
I think he means the little metal riser on the top-side of the valve core. you know, where the slot in the shrader valve tool fits onto... in which case, there shouldn't be any metal in the A/C system, but the next time that valve core needs to come out, he is boned.
Old Jul 21, 2017 | 08:20 AM
tony_2018's Avatar
Fish Twig
Can't tell, no pictures. Car language differ's from coast to coast, north to south.
Old Jul 21, 2017 | 01:29 PM
dgdarien's Avatar
Yes this is right; it has no effect on sealing the system and no metal pieces went into the system.
I went ahead and charged the system and it seems to be holding pressure as well. I figure if the port ever does leak then I can consider replacing the whole pipe or adding one of these couplers as a different source of sealing?
Old Jul 21, 2017 | 05:15 PM
tony_2018's Avatar
Fish Twig
I never used that crap to pull a vacuum or add refridgerant. It ***** up your valves.
NightHawk92
Jun 26, 2017 08:58 PM
integraboi1010
Sep 10, 2008 03:15 PM
Draggin99Si
Jan 21, 2006 09:13 PM
mdmitch2
Jun 23, 2005 02:34 PM
djcaseanova
Oct 7, 2003 07:59 PM
