Cranks, No Start. Injectors? Paypal Ready!
Old Jul 15, 2017 | 08:26 PM
TheDonOG's Avatar
Icon5 Cranks, No Start. Injectors? Paypal Ready!
Problem: Cranks but no start.
  • Fuel Rail has pressure 20psi
    • All Injectors are not spraying fuel
      • Tested injectors individually all click/open.
      • Tested fuel injectors electrical connections with test light. Test light lights up when cranking.
  • There is spark
  • Timing is good
Background:
The car is a 1999 Acura Integra, I swapped in a motor from a 1994 Integra.
I am using an Obd2a to Obd1 conversion harness with an Obd1 ECU (
Amazon Amazon
Brand new Obd2 distributor
Obd2 alternator
Checked/Tested Main Relay
Charged the battery
This motor was sitting for a a year. Could this have anything to do with it?
Is it my ECU? (was working fine before)
I need this car for work and school I am PayPal ready to pay anyone who helps me solve this problem!
Old Jul 16, 2017 | 08:14 PM
Drewk909's Avatar
Default Re: Cranks, No Start. Injectors? Paypal Ready!
Fuel pressure is usually around 50-60 psi if everything Is right I believe.
Try disconnecting the fuel line at the fuel filter and turn the key on. If a good amount of gas comes out then your problem will lie somewhere from the fuel filter forward. (Rail, Injectors, Filter)
If nothing really comes out it's probably your fuel pump. When you turn the key on listen to see if the pump is priming. (Even if it primes it could still be bad though)
Good Luck!
Old Jul 20, 2017 | 03:04 PM
TheDonOG's Avatar
My fuel pressure is fine, sorry it was not at 20psi. Fuel gets all the way to the injectors. They are just not spraying even though they are receiving a pulse.
I just swapped out the motor and am having the same issue crank no start.
Anyone have an idea?
Old Jul 20, 2017 | 04:30 PM
tony_2018's Avatar
Fish Twig
Check your engine harness for any loose connections
Old Jul 20, 2017 | 09:05 PM
Drewk909's Avatar
Are you still using the same injectors or different ones since you swapped the motor?
Old Jul 20, 2017 | 10:04 PM
wunfstgsr's Avatar
Loved
Community Favorite
  • There is spark
  • Timing is good
Background:
I am using an Obd2a to Obd1 conversion harness with an Obd1 ECU (https://www.amazon.com/Conversion-Ha.../dp/B00JR41VHG)
Obd2 alternator
Charged the battery
Is the injectors obd2 as well as the engine harness ? If not it could be that the injectors and engine harness is Obd1 and the ob2a to obd1 harness to Obd1 ECU is reading the engine harness as obd2 but it's really obd1. So you might need a obd2 engine harness from a 96-99 and use the obd2 injectors so the conversion harness is a true Obd2a to obd1 to the obd1 ecu. 94 engine is obd1
Old Jul 22, 2017 | 11:21 PM
TheDonOG's Avatar
Hey thanks for all the reply's everyone here is the update!
I swapped back in the old motor and I am still having this issue (when I pulled the motor it started up perfectly fine)
So now I am using an obd2 harness, ecu, and motor. No more conversion/no obd1
@Tony_2018 I will check all connections on the harness in the morning, Could it possibly be a bad ground? I double checked and triple checked the ground on the thermostat.
@drewk909 I was and still am using the obd2 harness seeing as how the obd1 had different connectors
@wunfstgsr the injectors are obd2 as well as the harness.
Can anyone send me in the right direction when it comes to diagnosing why the injectors are not firing even though they are receiving a pulse?
Could it be possible that all four injectors went bad at the same time?(I don't believe this is likely)
Old Jul 24, 2017 | 01:17 PM
TheDonOG's Avatar
I unplugged my alarm and now I am getting fuel now. Still no start but I am guessing I flooded the cylinder. I will check back in tonight thanks for the help everyone.
grrttwright
25
Mar 31, 2018 06:38 AM
ef-hatchcrap
Feb 11, 2010 11:49 AM
Kusai.Nihonjin.Desu
21
Apr 16, 2005 08:08 PM
BseriesN1
Jun 13, 2004 07:24 PM
EGHatchy
Jul 14, 2002 11:25 AM
