OBD port no communication with ECU
Old Jul 11, 2017 | 09:02 AM
Bleakened's Avatar
Default OBD port no communication with ECU
Hello, H-T!
I just did an entire B16A swap with EK9 CTR ECU into my 98 hatch.
I swapped motor, transmission and the entire dash with full HVAC system as well. In total, I converted the whole car from OBD2a to OBD2b.
Before the swap, the OBD port communicated with the ECU just fine and I could pull codes with my bluetooth scan tool but now it will not communicate.
Details:
1. OBD port does get power, the bluetooth tool powers up and connects to my phone. Also check photo below.
2. CEL light works on the instrument cluster and does it's normal 'startup check' of the CEL illuminating for a few seconds then turning off again.
3. I know the CEL should be on because I don't have either o2 sensors plugged in.
4. ECU works normally. VTEC engages, everything on instrument cluster works, idles and drives like normal.
It is a genuine EK9 CTR ECU with factory markings and I looked up the serial number identifying it.
I used to pull codes fine but now I can't - maybe I missed a plug when doing all of the interior harnesses?
Need help!
Old Jul 11, 2017 | 09:09 AM
Megalodong's Avatar
Default Re: OBD port no communication with ECU
Call or email the manufacturer of the BT scan tool...one their tech's should be able to help you sort it out.
Old Jul 11, 2017 | 09:13 AM
1999 Civic Si's Avatar
When you were able to communicate with the ecu via the obd2 port, what ecu were you using? My understanding is the JDM ecu's won't work with the USDM odb2 ports or scanners.
Old Jul 11, 2017 | 09:20 AM
Bleakened's Avatar
It's the same ECU I've always used for this motor. Could it be that the ECU is chipped or reprogrammed and maybe my scanner tool is faulty?
Old Jul 11, 2017 | 09:25 AM
Bleakened's Avatar
Also, is it normal that it should have codes but the light doesn't stay lit after the startup check?
Old Jul 11, 2017 | 10:15 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Can you provide the complete ECU number from the label on the ECU?
37820-xxx-xxx
Fill in the "x"'s.
Also, you can open the ECU case and see if it's chipped. If it is, that might be good information to provide instead of guessing whether it is or not.
Old Jul 11, 2017 | 01:49 PM
Bleakened's Avatar
37820-xxx-xxx
Fill in the "x"'s.
37820-PCT-J11
I am not experienced in ECU's. How can I tell if it's chipped once I look inside?
Old Jul 11, 2017 | 02:17 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Doesn't matter, the J11 says it's a JDM ECU so will not work with USDM OBD2 scanners as was stated earlier.
Thanks for providing the additional info.
But if you are still interested you can goto xenocron.com and see what and where the chipping goes on the ECU board.
ramboPandA
Apr 5, 2015 06:20 PM
bk7794
May 29, 2012 09:32 AM
zerovandez
Sep 15, 2009 01:13 PM
Tyteg
Apr 25, 2007 10:32 AM
h8tred
Jul 7, 2003 08:35 PM
