Oil Leak in timing belt area
Old Jul 8, 2017 | 09:07 PM
grizz210's Avatar
Default Oil Leak in timing belt area
My 96 Civic EX D15 Vtec developed an oil leak 8 months after replacing the timing belt, water pump and seals.
Thought for sure it must be the crank seal, but upon removing the covers and pulley I am not so sure. With the crank pulley off i want to start it and see where the leak is coming from but am unsure how tight the crank pulley bolt needs to be. I for sure cant tighten it to spec without putting the pulley back on, which may get it the way of seeing the leak. It usually leaks within a couple of minutes at idle, so it does not have to run for long.
I am looking for any comments from anyone who has done this. i sure dont want to ruin my motor
Old Jul 9, 2017 | 04:54 AM
Lineman's Avatar
Default Re: Oil Leak in timing belt area
You can do it just might have to charge battery depending on how long you run it.
Old Jul 9, 2017 | 11:53 AM
grizz210's Avatar
yea I know i can do it, just wondering how tight that crank bolt needs to be for a short run at idle... I for sure can't get it to torque specs without the pulley on..
Old Jul 9, 2017 | 12:56 PM
tony_2018's Avatar
Fish Twig
Hard to say with your engine code.
civiclady
Sep 13, 2015 06:33 AM
ABCVTEC
Nov 19, 2010 02:20 PM
pyk012
Oct 4, 2005 11:26 AM
blackdelslo
Dec 15, 2004 02:02 PM
Ryan C
Mar 25, 2004 06:30 AM
