Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
still receiving P1361 code after replacing camshaft sensor. What could be the issue?
Old Jul 8, 2017 | 03:36 PM
Rannk's Avatar
Default still receiving P1361 code after replacing camshaft sensor. What could be the issue?
Car still goes into limp mode with P1361 code after replacing TDC sensor. The problem first happened about a month ago, and again yesterday. Replaced the sensor this morning and now the car can barely make it a few blocks without any issues.
Old Jul 23, 2017 | 11:58 AM
cssmith's Avatar
Default Re: still receiving P1361 code after replacing camshaft sensor. What could be the iss
Make sure the wires to the connector are not loose. Have you tested the connector that comes to your sensor for the correct voltages? Unplug sensor. Turn ignition on. Measure voltage between the TDC sensor 3P connector terminal No. 3 (yel/blk wire on mine) and body ground. Is there battery voltage? Measure voltage between the TDC sensor 3P connector terminal No. 2 (green wire on mine) and body ground. Is there about 5 volts? Measure voltage between the TDC sensor 3P connector terminals No. 1 (brn/yel wire) and No. 3 (yel/black wire). Is there battery voltage?
Old Jul 23, 2017 | 12:13 PM
cssmith's Avatar
Is your car a 2001 ex? If so the first thing you need to look up is the service bulletin Honda put out for the P1361 code to see if your car is a part of it. Just google 2001 civic P1361 service bulletin.
Old May 26, 2024 | 12:29 PM
Cata's Avatar
MY N.2 (Green wire only has 1.2 V what can I do?
TammyM1978
19
Nov 17, 2020 05:33 AM
sinceasar
Jan 25, 2013 04:17 AM
redeg61987
Apr 29, 2007 06:58 AM
pbadger
Nov 14, 2004 12:50 PM
LoudAccord
Mar 27, 2003 07:12 PM
