B16B EM1 swap
I'm thinking about doing a B16B swap into a EM1 chassis. Is there like a differences between the B16A2 and B16B (besides the performance spec) in terms of wiring harness, tranny, etc...? Or is it one of those direct bolt in type of swap. From the look of it, the two engines look nearly identical.
You're going to run into harness issues. You'll have no tach if you use the b16b ecu with an adapter, and you won't be able to scan the car for codes, jdm ecu's dont use the OBD2 plug. I just swapped a 2000 JDM B18C ITR into my 2000 EM1 and ran into some stuff. I have to pass emissions so I'm trying to make the car think it's a b16a2 lol. Do you have to pass emissions or anything? You can use your current axles if you plan on using your stock hubs. Motor mounts should be the same. What ECU do you plan on running?
Start reading here if you are concerned about emissions testing... google can also offer more recent articles as well.
How To Smog your Honda Swap - My Pro Street
https://honda-tech.com/forums/tech-m...gines-2905764/
You will be able to use 99% of the items from your B16A2 on the B16B long block. Fitment wise, you will be fine. You can use your EM1 harness but certain plugs may/will not be used (such as the VTEC oil pressure switch). However, if you need it to be emissions legal you will need to swap over a number of things to the B16B motor in order for it [B16A2 ECU] to "run" the B16B and communicate with your OBD2 port.
You should have taken the route to make the car think the JDM ITR motor is a USDM ITR motor with a B18C5 ECU. I wonder if your tachometer issues were related to the fact that OBD2 motors have their crank position sensors located on the oil pump instead of the distributor...
I'm planning to use the current B16A2 ECU. No, i don't have to pass any emissions test. When you say no tach, do you mean as in no reading from the tachometer? So how do i scan for codes if there's no OBD2 plug? I supposed i can use the current ECU i supposed, if it's okay that is.
99% swap compatibility sounds good. What all else need to make the swap go smoothly again? I seriously don't wanna run into major issues 1/4 down the road ya know.
DualCam_V
24
Aug 27, 2010 02:37 PM
UNforgivABLE
Feb 25, 2009 05:16 PM
