Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Why is the side mirror still loose?
Old Jul 5, 2017 | 08:48 AM
debodun's Avatar
5 Year Member
Default Why is the side mirror still loose?
My 2002 Honda Civic LX sedan has a loose passenger-side mirror. I tightened the bolts which weren't terribly loose. It helped a LITTLE, but it is still somewhat wobbly. What could be the problem?
Old Jul 5, 2017 | 12:49 PM
toyomatt84's Avatar
Sanji
Default Re: Why is the side mirror still loose?
Is the mirror glass mount loose? Meaning, the mirror wobbles inside the housing? Or does the entire housing wobble?
Old Jul 9, 2017 | 06:48 AM
debodun's Avatar
5 Year Member
The whole housing is loose.
Old Jul 9, 2017 | 08:23 AM
toyomatt84's Avatar
Sanji
Is there a seal between the base of the mirror housing and the car? (Looks like a rubber gasket)
Old Jul 9, 2017 | 09:24 AM
debodun's Avatar
5 Year Member
There doesn't appear to be any gasket.
Old Jul 9, 2017 | 02:47 PM
toyomatt84's Avatar
Sanji
There should be:
Old Jul 11, 2017 | 08:34 AM
debodun's Avatar
5 Year Member
Where would the gasket you mentioned be located? Attached is a photo of the mirror in question. It is loosest on the bottom front corner.
Old Jul 11, 2017 | 03:42 PM
toyomatt84's Avatar
Sanji
Old Jul 12, 2017 | 08:10 AM
debodun's Avatar
5 Year Member
Okay, it's between the mirror and car body, hidden when mirror is in place. So I do have a gasket, but the nut for that bottom front corner just turns without tightening and the mirror mount will not come flush with the car body.
Old Jul 12, 2017 | 06:27 PM
toyomatt84's Avatar
Sanji
Can you turn the nut continuously? If so, the stud itself is broken free in the mirror. You'll need to find a way to secure the stud to the mirror, be it with epoxy or something else... otherwise it'll never tighten up.
Old Jul 13, 2017 | 04:52 AM
NDNV's Avatar
If it is just the nut (5 mm flange and part #94050-05080) that is stripped, then try a new one on that bolt. If the bolt spins freely, then I am not sure how to disassemble the mirror to get to it as the parts diagram shows it as part of the mirror assembly and not a separate part.
dk015
Jul 24, 2015 08:15 AM
Dekorum
Apr 12, 2011 08:47 AM
