Which is camshaft for b18c 12.9 compression?
Old Jul 2, 2017 | 06:03 AM
ardaaykan's Avatar
Default Which is camshaft for b18c 12.9 compression?
Now i have skunk 2 Pro 1 but i feel this camshaft is soft...What do you think?What can i use?
Old Jul 2, 2017 | 08:37 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Which is camshaft for b18c 12.9 compression?
What technical questions do you have?
Opinion solicitation isn't kosher in the technical section and can get the thread closed.
Old Jul 2, 2017 | 10:12 AM
Chance EG's Avatar
With a CR that high you could probably go with a pretty aggressive cam. Pro 3's or comparable cams would likely yield some pretty good gains assuming the head flow and intake/exhaust manifolds could keep up with it.
Lot of other variables to consider there too, and they'd have to be degree'd in properly. Would need to make sure you don't get any P2V contact as well. I'd consult your tuner.
Not even going to pretend like I'm familiar with other manufacture cams either honestly, there are definitely other options besides the Skunk2 lineup but that's all I've ever used or really looked into...
Old Jul 2, 2017 | 06:36 PM
98civdx's Avatar
Master Detailer
You'd likely have better luck in the all motor section.
Old Jul 12, 2017 | 04:50 PM
ardaaykan's Avatar
Thank you for answer...i want to try s2 ultra series 1 i m waiting for this camshaft...
Old Jul 12, 2017 | 05:56 PM
ontariorider's Avatar
Curious do u mind sharing the supporting mods? Pro1 is a nice cam for most 1.8L with similar compression..e85 or pump gas?
Lonewolf1983
36
Nov 6, 2014 08:24 AM
OrangeTeggy
Jan 6, 2010 11:42 PM
juan3023
15
Mar 13, 2009 01:26 PM
honkyb18c
14
Oct 10, 2008 02:07 PM
EKB18C97
17
May 2, 2006 03:30 PM
