Honda CR-V & Element 2WD & 4WD Element & CR-V
Air conditioner unreliable
Old Jun 29, 2017 | 01:00 PM
kissrn's Avatar
Default Air conditioner unreliable
I have a 2008 Honda CRV. I recently started having problems with the ac. It works perfectly well when first started.When the car is started, driven,turned off and the car is restarted the sir conditioner does not work. I had it checked by a non-Honda mechanic. He found a small fluid leak from a connection but no other problem after running a diagnostic test. He flushed and refilled the fluid. It worked fine for a few days and the same thing happened.
Old Jun 29, 2017 | 06:40 PM
Smackin's Avatar
5 Year Member
Loved
Community Favorite
Default Re: Air conditioner unreliable
Originally Posted by kissrn
found a small fluid leak from a connection.
Did you have the leak repaired?
If it worked completely for a few days after your mechanic recharged the a/c system then works intermittently, it sounds like you have a leak.
Did he use an A/C machine for diagnostics? I have a couple at work... I've used the diagnostic test on my CRV, and it failed to detect the leak that i definitely have Hah. Technology.
prodjay10
Nov 16, 2014 06:41 PM
bladers10
Honda Civic (2006 - 2015)
Oct 19, 2010 10:00 AM
CaliforniaDad
Jul 19, 2010 04:50 PM
stickercuttingcom
Mar 13, 2006 02:39 PM
Skippy
Jul 24, 2002 10:32 AM
