Air Conditioning problem
Old Jul 23, 2002 | 11:07 AM
Skippy's Avatar
Default Air Conditioning problem
99 GSR and MY AC isn't blowing out cold air. I have had it recharged. Any suggestions on how to fix this...Leather sux in 100 degree weather...lol
Old Jul 23, 2002 | 11:08 AM
Skippy's Avatar
Default Re: Air Conditioning problem (Superchargedb18c)
Please shoot me an email if you know! superchargedb18c1@yahoo.com
Old Jul 23, 2002 | 11:19 AM
LostGsr's Avatar
Did you have a professional recharge it for you and did you do it yourself?
Old Jul 23, 2002 | 12:55 PM
Skippy's Avatar
Default Re: Air Conditioning problem (LostGsr)
Yes, I had Acura dealership recharge it. Worked for like 2 days then went to hot air again!
Old Jul 23, 2002 | 01:51 PM
GSRaCeRbOI's Avatar
since the recharge didn't work.. or worked for 2 days then went hot again.. you probably had a leak somewhere in your a/c system/lines.. you should take it to an A/C shop and have them pressure test/test for leaks... not sure if your warranty is still good.. you might want to take it to the dealer if it is..
Old Jul 23, 2002 | 02:47 PM
LostGsr's Avatar
Default Re: Air Conditioning problem (GSRaCeRbOI)
I have to agree with GSRaCeRboI. It is likely a leak somewhere. Go back to the dealership and they will pump a dye into the system to locate your leak. Goodluck
Old Jul 23, 2002 | 03:02 PM
Just_LS's Avatar
Check your a/c line below the bumper. Mine was cracked probably due to a rock. Cost about $100 to fix it. Do a search, someone had the same problem before and another member even show a picture as where the line is.
Old Jul 23, 2002 | 03:11 PM
MisterHYBRID's Avatar
Default Re: Air Conditioning problem (Just_LS)
my ac is having the same problem, i was wondering which fan is supposed to spin when the ac is on? because neither of mine are spinning....
Old Jul 23, 2002 | 03:36 PM
GSRaCeRbOI's Avatar
Default Re: Air Conditioning problem (MisterHYBRID)
the fan closer to the drivers side w/ that blue cap (A/C low line cap/line) is the A/C fan... and the fan w/ the radiator/coolant bottle is the radiator fan... I'm not sure but I think it cycles on and off depending on temperature .. maybe when you were looking at it.. your motor wasn't hot enough.. or maybe you have a malfunction not sure how its wired up....
Old Jul 23, 2002 | 06:00 PM
Farnsrocket's Avatar
I just ripped mine all out (95GSR)........well, took it out very carefully...........if you need to buy something, let me know.
Old Jul 23, 2002 | 06:29 PM
Default Re: Air Conditioning problem (Farnsrocket)
if i knew what was wrong with mine i might buy something from you.
Old Jul 23, 2002 | 06:59 PM
rodimus's Avatar
OMG and you're in vegas.
you'll be in my prayers...
lol
Old Jul 23, 2002 | 11:59 PM
bullz's Avatar
Default Re: Air Conditioning problem (EVOL)
Don't feel bad. I've had no AC for about 2.5 years already... and living in Palm Springs
Old Jul 24, 2002 | 12:34 AM
:jdmshmaydm:'s Avatar
Default Re: Air Conditioning problem (illestjr)
I'm in Arizona with no A/C. Mine blows hot air only too. I was thinking about getting it recharged pretty soon cause in Phoenix the heat is like...damn
Old Jul 24, 2002 | 12:48 AM
blanktape's Avatar
from ur nickname i assume u have JRSC...
cuz with JRSC the intake manfoild sits lower so it might rob the A/C pipe...check on that u might have a leak...
Old Jul 24, 2002 | 01:50 AM
VTi NA's Avatar
Default Re: Air Conditioning problem (Gatecrasher18AF)
<-- Was just in Phx...you're the man if you can stand that heat. Good god, I cant even stand the weather here in CA withouth AC.
Old Jul 24, 2002 | 03:29 AM
EVOTHIS's Avatar
Default Re: Air Conditioning problem (STi -RA)
I work for acura and can tell you that you have a leak somewhere, you will need to add freon and dye to your A/C system and then run a black light over everything to find out where the leak is. if you can't find a leak that way it could be your expansion valve.
Old Jul 24, 2002 | 10:13 AM
Skippy's Avatar
Default Re: Air Conditioning problem (b18c ya)
Thanks all!
Old Jul 24, 2002 | 10:21 AM
bamaTeg's Avatar
New User
it could have been me that had your same problem. Mine was a cracked suction line which did cost about $100 for just the line and another $25- $50 for labor.
Old Jul 24, 2002 | 10:32 AM
LTB420's Avatar
Default Re: Air Conditioning problem (bamaTeg)
i had a similar prob. with my AC. it turned out to be that my fan was bad and would blow the fuse in the engine compartment when i turned it on.
bladers10
Honda Civic (2006 - 2015)
Oct 19, 2010 10:00 AM
M4
May 13, 2005 06:51 AM
integra dave
Acura TL, RL & ZDX
Jul 7, 2003 12:33 PM
