Clutch pedal back on the floor after bleed......
OK, so me and my dad bled the clutch il the pedal was solid and air free, then overnight, the pedal is back on the floor again like we never did anything........
why?? i mean, what is causing it to do this?? I think its the 3rd time we have bled it free of bubbles........?
Thanks for the help.....
we did i would pump the pedal, then dad would turn the nipple releasing the air, 5 or 6 times until it was air free, and the pedal was stiff out and off the floor, it felt fine then. Its an old master cylinder, but there are no leaks from that OR the slave. But next morning, back to the floor, like we hadnt done anything at all.......
The seal inside the master may have bit the dust. If its old, might as well get replacement.. stay away from auto store type. Get exedy, oem maker for clutch master and slave. Yes, its cheap and worth it without paying oem price..
http://shop.exedyusa.com/1999-honda-civic-ex-4cyl-16l/a-9252174.aspx
if link dont work. Go to exedyusa.com
put in your car info.
for less then $30 you can get oem quality. Yes, that is for BOTH master and slave. Below $30.. always replace both at the same time.
gooblinn258
Jan 18, 2014 05:02 PM
