Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
09 Pilot oil consumption
Old Jun 26, 2017 | 08:13 AM
tvbh40a's Avatar
Default 09 Pilot oil consumption
Long time Honda owner. This is the first one to use oil. 118k miles. About a qt/1k miles. Any ideas on how I should proceed? cheap fixes?
Old Jun 26, 2017 | 05:38 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: 09 Pilot oil consumption
Issue is probably due to the piston oil control rings. You can check the PCV valve and replace it if necessary; but, that may not make a big difference if it is not clogged up.
If it is burning oil due to the oil control rings, at this point, regularly checking and adding oil would be most cost/effective.
Old Jun 27, 2017 | 03:53 AM
speedlever's Avatar
Is it safe to assume your 09 Pilot has VCM? If so, this is likely the cause of your excessive oil consumption and is a known issue.
You could try the VCMuzzler, but it may be too late to fix the current problem that may require re-ringing your engine to properly address the issue.
Here's one reference point:
https://slickdeals.net/f/6221520-hon...rs-see-post-26
Old Jun 27, 2017 | 05:04 AM
sissina's Avatar
All honda V6 eat oil.. The generation 6 ones the transmissions die at 160,000 k. In calgary no taxi driver will drive an Accord. They must know something.
Old Jun 27, 2017 | 06:08 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Depending on when your 2009 Pilot was purchased, the warranty extension may or
may not be over. For example, a 2009 model purchased in late 2008 would have gone over the 7 year extended warranty.
You would also have to be experiencing the specified misfire codes.
The piston oil control rings would be replaced on the affected pistons if covered.
File Type: pdf
Old Jun 27, 2017 | 08:36 AM
speedlever's Avatar
That has not been my experience with a 2006 Pilot AWD with 140,000 miles and a 2008 Ridgeline with 106,000 miles. My typical oil change intervals are 6500-7000 miles and I never have to add any oil between changes. Neither of these vehicles have VCM.
Old Jun 27, 2017 | 06:28 PM
tvbh40a's Avatar
I went in to the dealer where I purchased the Pilot. Was told no recalls, TSB's or extended warranty offers. They are definitely aware of the issue and it would be around 5K to repair. I laughed and walked.
Old Jun 27, 2017 | 06:58 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
See the attached TSB in my last post.
herdofcaribou
Oct 22, 2018 04:28 AM
velozp
Honda CR-V & Element
Aug 21, 2017 06:18 AM
fernando.
33
May 1, 2009 09:28 AM
