Transmission & Drivetrain Gearboxes, Differentials, Clutches
EK tranny on EG, which clutch/flywheel to use
Old Jun 17, 2017 | 12:47 PM
cpwtheeuwes's Avatar
Default EK tranny on EG, which clutch/flywheel to use
Hi there,
So i've got a D15 - Z6 minime engine which i'm about to turbo. Planning on around 200HP.
The tranny on it now is the oem s20 tranny that came on the D15B2 engine. I am planning on swapping this tranny for a s40 from an EK3.
Reason is the EK3 is a vtec-e and has some of the longest gear ratios and i would like to have a higher top speed.
So the standard clutch diameter for my current tranny is 212mm and for the EK3 tranny its 200mm.
What kind of setup do i need to run?
Do i keep my current flywheel with a 200mm clutch, or can i keep my current clutch and flywheel, or do i need to buy all s40 flywheel and clutch.
If someone could shed some light on to this i would be very happy.
Old Jun 17, 2017 | 08:47 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: EK tranny on EG, which clutch/flywheel to use
You can use either clutch/flywheel combination.
Old Jun 17, 2017 | 09:37 PM
Aquafina's Avatar
Like was already stated you can run either. I would run the shorter transmission. With a stock rev limit and standard 23" tires, you'll still have a top speed of 166mph.
aemintgsr
16
Jul 19, 2009 08:16 PM
BlkCivicFromTeamMNR.com
Jul 26, 2007 11:53 AM
VegaS10
Mar 16, 2006 04:08 PM
honcrx91si
Aug 14, 2005 08:56 PM
crxb20ed
Aug 14, 2004 11:52 AM
