Honda CR-V & Element 2WD & 4WD Element & CR-V
06 Honda CR-V water leak
Old Jun 14, 2017 | 12:07 PM
marjorieanna's Avatar
Default 06 Honda CR-V water leak
I have a 2006 Honda CR-V with a leak that drips down from around my gas pedal every time it rains. I have already taken it in to be looked and and have ruled out a windshield leak and sunroof leak. Any ideas as to where the water is getting in from?
Old Jun 15, 2017 | 05:01 PM
Smackin's Avatar
5 Year Member
Loved
Community Favorite
Default Re: 06 Honda CR-V water leak
If the sunroof and windshield have been ruled out, I would think it's leaking somewhere from the cowl area.
Run a low pressure water hose to different areas of the cowl for a minute or so and see if you get water inside around the pedal.
Old Jun 15, 2017 | 05:21 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
There is a service bulletin regarding the passenger compartment front bulkhead not properly sealed. The fix is to remove the cowl and apply sealant to the entire exterior horizontal seam on the front bulkhead.
Old Jul 3, 2017 | 11:08 AM
Occidentalis's Avatar
May not be it but there is also a clutch cutout hole above the gas pedal. It shouldn't be popped out in A/T but it is there, should be easy to check behind the black cladded sound dampening firewall pad. Should be easy enough to spot because the cutout is in the pad just unused, and if water is dripping through there from above you can rule it out by if it's wet above it or not.
Creature1
Honda Civic (2001 - 2005)
May 5, 2014 10:13 AM
pinoyboiwonder
14
Nov 11, 2006 06:00 PM
blaisepascal
Oct 15, 2004 10:32 AM
passport1
Acura TL, RL & ZDX
May 20, 2003 04:33 PM
