bogging issues
Old Jun 13, 2017 | 07:13 PM
montanacivic's Avatar
Default bogging issues
88 CRX d16z6. Car idles perfect but as soon as its given gas it bobbles. Only code its given is for a iacv which was replaced an code is still there. Checked an I'm getting no power to the iacv. Break in the wire or possibly bad ecu??
Old Jun 14, 2017 | 03:57 AM
existanzcivicb20's Avatar
Default Re: bogging issues
I would run a new wire and go from there
Old Jun 14, 2017 | 08:13 AM
What's the worst case scenario??
Old Jun 14, 2017 | 08:48 AM
beeza's Avatar
Car catches on fire lol
I would check IACV wires for power at the ecu end,this will determine if it's a faulty wire.
Old Jun 14, 2017 | 08:58 AM
Anything can catch fire lmao.. I haven't bought the car yet. Don't want to unless I know its a easy fix.. I thought a no iacv would cause a rough idle?? Car idles perfect but once ya give it gas it bogs down.. I just want to know in the worst case what would I be looking at?? A whole rewire or?? I assume I could run the 12v iacv wire to a keyed 12v??
Old Jun 14, 2017 | 09:32 AM
beeza's Avatar
best to try what you know! Very hard to say without the car...if may need to get someone to have a look..
Sounds like it's worth checking the tps voltages because it can cause this issue and if it's out you can adjust it as close as you can easily and then try and drive it.
Old Jun 14, 2017 | 10:25 AM
I'm a mechanic but don't know crap about Hondas period. I would hate to buy it an end up dropping tons of cash into it. My most concern is having to rewire the while car..
Old Jun 14, 2017 | 10:57 AM
beeza's Avatar
Clogged fuel filter can cause this too:
https://honda-tech.com/how-tos/a/hon...-system-376305
Old Jun 15, 2017 | 07:15 AM
Odixeus's Avatar
Yeah, you should check it with a new wire imo.
Trex88dx
Jul 12, 2012 08:15 PM
santii7
Jun 21, 2011 07:22 AM
h22blklude92
Jun 14, 2011 05:23 PM
slo6gen
May 17, 2007 02:43 PM
UpstateCivic
May 26, 2003 07:01 PM
