Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Vsa light comes on after I start moving
Old Jun 13, 2017 | 02:28 PM
Rod06's Avatar
Default Vsa light comes on after I start moving
I changed my rack and pinion, axles and struts on my 2006 Honda Ridgeline, my Vsa light comes on when the truck start to move.
Old Jun 13, 2017 | 02:43 PM
burnoutboy's Avatar
The Credible Hulk
Default Re: Vsa light comes on after I start moving
I believe the VSA operates off a "yaw sensor" that detects if the wheel is centered properly and a steering angle sensor. Yaw sensor should be in the center console towards rear end of it. Steering angle sensor is in the steering column.
A) If you replaced with an aftermarket rack does it have all the same connectors as the OE one and are they all hooked up?
B) Did you make sure the rack was properly centered before install?
Old Jun 14, 2017 | 07:20 AM
speedlever's Avatar
I suspect a wheel sensor might be a simple initial check. But the list of things that can illuminate the VSA light is long.
2Accords
Aug 24, 2011 06:21 AM
Prudz_lude
Apr 3, 2011 11:08 AM
93SiPrelude
Nov 11, 2007 05:15 PM
