HELP H23a in 2000 EK Coupe
Old Jun 9, 2017 | 07:10 AM
coupeek's Avatar
Default HELP H23a in 2000 EK Coupe
What's up guys so I've run into a couple problems with my motor mounts, the driver side mount on the engine has two bolts that are closer then my motor mounts that I ordered so essentially the driver side doesn't fit but I haven't tried the others is this because my engine possibly came out of the SIR CH9 instead of the 97-01 prelude? I had gotten this engine from JDM Depot in New Jersey but I can't tell which model car it came out of can anyone give me tips on where to look to know? Here's some pictures if it helps
Old Jun 14, 2017 | 04:35 AM
cmwright1986's Avatar
Default Re: HELP H23a in 2000 EK Coupe
For an h23a you have to use the drivers side mount off of an h22 or h23a1 for it to work
Old Jun 19, 2017 | 10:34 AM
coupeek's Avatar
So all of my other motor mounts should be fine to put in? I just need the drivers side mount from a H22? And just one other thing, the motor I have is from Japan it's the SIR CH9 Accord engine. Does that still matter or no?
Old Jun 19, 2017 | 09:09 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
You need a driver's side H22 Engine Bracket... the part that bolts in inside the timing covers. This will work with the mount kit that you have pictured.
Old Jun 20, 2017 | 04:37 AM
Make sure you also use the rear mount from a 5 speed, not an auto.
djcam954
10
Nov 9, 2011 06:41 AM
nwstreets
Nov 8, 2009 11:08 AM
JDMrasta
Aug 5, 2007 07:26 PM
bambbrose
Jun 13, 2007 09:22 PM
nub.96ek
Jan 19, 2006 02:16 PM
