Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
1995 passport water leak
Old Jun 8, 2017 | 04:52 PM
Becca165's Avatar
Icon5 1995 passport water leak
Please I'm from a small town and the mechanics here do not know much about Hondas I have one Ford Company in my town and one grocery store my problem is that I have a leak underneath and seems to be in the middle or two rear of the engine and right now it only looks like it's coming off the pan down there not really sure where it's coming from I've been told it was a freeze plug although you have to drop the transmission to get to the freeze plugs is what Ford says but they're really not sure for the truck is cranked in the morning to make sure it has plenty of water in it now with the fans working correctly and trying to drive to work about three to four miles away I lose no water until I stop the vehicle when I get out of the vehicle all the water comes pouring out if I make a stop at a gas station or something like that I leave the vehicle running and it barely drips if I turn the vehicle off the water comes out does anyone have any ideas of what this could be I'm desperate for help
Old Aug 4, 2017 | 07:34 PM
Brian Rebitzke's Avatar
Default Re: 1995 passport water leak
if it has the 3.2l engine it's probably a couple o-rings that are underneath intake manifold. The pipes are connected to radiator run under the intake manifold connect up to the heater lines. I just replaced them this week. Real pita for a 70 cent part you end up replacing all the gaskets intake, Thermostat , thottlebody, egr, and you should also replace any other hoses to heater end3d up costing me about $150 In gaskets hoses and clamps ect.ect..... good luck with it but probably not the freeze plugs.
Rabbitski
dlenoxx
Dec 2, 2010 12:05 PM
Dekorum
18
Sep 28, 2010 07:55 AM
pinoyboiwonder
14
Nov 11, 2006 06:00 PM
Liquid Ice NF
Aug 12, 2005 05:52 PM
