Running poorly after dizzy install
Old Jun 5, 2017 | 05:33 AM
C-West Civic's Avatar
Default Running poorly after dizzy install
After replacing the dizzy, the engine runs very rough at start up. Will take a few cranks for it to finally stay running at idle, but when she gets there, it sounds like the video. Only after a few minutes ( engine warms up ) she gets straight and runs right. Is this an issue with the dizzy not being in time and the the ECU correcting the idle?
https://www.facebook.com/chris.quagliata.5/videos/vb.1544396848/10212563034661220/?type=2&theater
Old Jun 5, 2017 | 05:36 AM
tony_2018's Avatar
Fish Twig
Default Re: Running poorly after dizzy install
Thanks for the video, I'd check your spark plug order.
Old Jun 5, 2017 | 06:04 AM
jorge74's Avatar
As Tony said check the spark wiring for one, you need to advance the dizzy and use a timing gun for correct timing.
Old Jun 5, 2017 | 06:10 AM
mk378's Avatar
Could be running on 2 cylinders. That will happen if you swap two of the spark wires. Spark plug order is 1-3-4-2 going clockwise looking at the outside of the distributor cap.
Also could be something else wrong with the car that wasn't fixed by distributor replacement so is still there.
Old Jun 5, 2017 | 06:48 AM
Checked firing order and its all good.
mk378 - when initial problem occured ( crank no start ), I swapped out coil and car started up several times normal, no issues. Car died, ran more tests and determined I had to swap out dizzy after rechecking coil and ICU ( both fine ).
Old Jun 5, 2017 | 11:58 AM
NotARaCist's Avatar
I never narc'd on nobody!
Setting ignition timing after replacing the distributor is not optional. Jump the service connector, put the timing light lead on wire 1, and get your timing where it belongs.
Tommy818
Jan 7, 2014 02:35 PM
Sturg
Oct 27, 2009 12:04 AM
98jdmcivic
Oct 12, 2008 06:45 PM
purplexs650d
Oct 17, 2006 12:31 PM
racin_fool
15
Jul 18, 2006 03:10 PM
