Set readiness monitors - Failing Smog - OBD2
I have a 97 honda civic dx model and I'm trying to get it to pass smog. I took for a smog test and everything was good except 2 monitors weren't set yet. I tried to set the readiness (using this guide) of my last 2 monitors that my odbII meter said was incomplete, which was the O2 sensor and EVAP. All of the others were already set. I ran this twice and nothing changed. I haven't disconnected the battery in about 500 miles. There are no error codes or check engine light. Any clue as to why this isn't working or what I should do next? Thanks!
Last edited by TomCat39; Jun 4, 2017 at 08:40 AM. Reason: fixing guide reference url
Ok, so only those two will reset or should all? The other monitor's don't reset, just the O2 and evap monitors. Where do I find the backup fuse under the hood? Is it in the smaller fuse box with the relays under the hood next to the battery?
Now that I think about it, it seems like all of the monitors would reset after I turn off the ignition. None have reset, it just looks like only 2 haven't completed their drive cycles even though I did it twice. Even when I repeatedly turn the engine off and on and check the obd2 monitor its always the same, all of the monitors ready ok and just 2 say incomplete. Anyone have any other ideas on how to fix this?
I listed the monitors in the original post,
"I tried to set the readiness (using this guide) of my last 2 monitors that my odbII meter said was incomplete, which was the O2 sensor and EVAP."
dth0ng69
13
Jan 8, 2020 01:09 PM
EFRue57
Apr 1, 2009 02:32 PM
jadsi420
Sep 14, 2005 08:01 AM
