Can Pre-ignition result from lack of valve adjustment after changing timing belts?
Old Jun 2, 2017 | 03:01 AM
4Gchildren's Avatar
Default Can Pre-ignition result from lack of valve adjustment after changing timing belts?
Can this be caused by valves needing adjustment after timing belt being changed thanks
Old Jun 2, 2017 | 07:09 PM
TheShodan's Avatar
Moderator
Default re: Can Pre-ignition result from lack of valve adjustment after changing timing belts?
No.
Old Jun 2, 2017 | 07:19 PM
DickensA's Avatar
Pre ignition is not the same as detonation
Old Jun 4, 2017 | 08:53 PM
motoxxxman's Avatar
Default Re: Can Pre-ignition result from lack of valve adjustment after changing timing belts
to clarify something here; changing the timing belt has zero effect on valve lash.
to clarify something else: valve lash being too tight can cause preignition, if the exhaust side is too tight. because if the exhaust valves hang open at any time, the exiting flamefront can backfeed back into the cylinder igniting the incoming air/fuel mixture, especially in turbo applications where there is frequent positive pressure in the exhaust ports of the head.
npoutre
Honda CR-V & Element
10
Jun 20, 2019 01:48 PM
journeyquest
Jul 10, 2011 12:34 PM
young geezer
May 21, 2009 08:37 AM
euG3dc2r
Feb 23, 2005 03:45 AM
vxnine
12
Oct 14, 2004 07:41 AM
