Problem starting crx
Old Jun 1, 2017 | 07:12 PM
CJCRX's Avatar
Default Problem starting crx
91 crx will crank but will not start, with the key off, the oil light will stay on verry dim. Started with just dying out at a stop, and restart was fine. Then it got harder to get it restarted. And now it just wont start.
Replaced
Ignition switch
Ignition coil
Spark plugs
Distributor cap
Please help
Last edited by CJCRX; Jun 1, 2017 at 07:16 PM. Reason: The lines were ran together
Old Jun 2, 2017 | 10:49 AM
boibuddha's Avatar
Default Re: Problem starting crx
Was the oil light on before the car died?
If so, then check your oil level. Adding oil won't fix anything but it will prevent any further damage.
If you didn't run your engine low on oil, I would look into the fuel side of things since you already did most of the electrical stuff.
- Try swapping in a new fuel filter if that hasn't been done in a while, it's cheap and can be done by anyone.
- Then re-flow the solder joints in the MAIN RELAY or replace it.
- Last thing to do would be the fuel pump.
Old Jun 2, 2017 | 03:42 PM
Tyson's Avatar
the problem seems like a dozen different other things that are easy to check than the things you replaced, but difficult to really help without playing 20 questions over the internet.
just take your car to a mechanic. could be something dumb like a bad battery.
Old Jun 2, 2017 | 04:41 PM
CJCRX's Avatar
Is the main relay the brown one under the drivers side thats hardish to get to? If not, where is it located? And its not a bad battery, its all but new. And i have a charger that i use when messing with the car. Going to re probe the destributor to make sure that its getting spark tonight.
Old Jun 2, 2017 | 05:10 PM
CJCRX's Avatar
Googled the main relay. Car came with one. Replaced it. The lights on the dash work as designed now and go completely off with the key.
​​​​ but
Turns out the spare relay that came with the car is also faulty and not kicking the pump on going to pick one up and seeing what that does
SOHC_civic_si
36
May 21, 2008 07:31 PM
crx18c1
11
Jun 18, 2007 06:42 PM
djnikko
Mar 18, 2004 03:56 AM
Driven
Jun 24, 2002 06:14 PM
