Suspension & Brakes Theory, alignment, spring rates....
rsx problems
Old May 31, 2017 | 08:17 PM
angelchavarin43's Avatar
Default rsx problems
hi my name is angel and i have an 02 rsx type s it is lowered and it keeps eating the inner side of the tire i have taken it to get aligned but i still have the same problem what can i do to fix it?
Old Jun 1, 2017 | 03:23 PM
k3ntegra's Avatar
Loved
Community Favorite
Default Re: rsx problems
When you take a car for an alignment you should ask for digital/laser measurements before and after the procedure; places that offer this will usually charge around $90. Inner tire wear, seems consistent with negative camber; which can be as a result of either lowering the car or a bent suspension part that may be unable to be seen with the naked eye. To adjust camber on RSX, you'll need to get a "camber adjustment kit".
https://www.youtube.com/watch?v=7v0w6FZMOOw
Old Jun 1, 2017 | 09:56 PM
motoxxxman's Avatar
inner tire wear can mean many things. bad toe adjustment is the #1 cause for it. camber doesn't kill tires, toe kills tires. BUT, camber CAN kill tires depending on your driving habits. even if toe is spot on, doing burnouts with negative camber will destroy the inside edge of the tires very quickly. same goes for if you do a lot of heavy braking at high speed. this would be the #2 cause. #3 cause would be a bad suspension component, allowing slop in the suspension and steering, throwing the toe off while driving.
Old Jun 5, 2017 | 10:43 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
RSX uses Mac struts in front, which doesn't gain much negative camber when lowering. My money would be on bad toe settings.
710dabber
Suspension & Brakes
Dec 17, 2015 10:18 PM
qhondak
Suspension & Brakes
Jan 31, 2008 08:07 AM
CivicRaping
12
Mar 10, 2005 05:51 PM
Todd00
39
Jun 8, 2004 06:45 AM
spork sport
19
Mar 12, 2002 09:02 PM
