how much can i lower a rsx without a camber kit?
Old 02-23-2005, 06:42 PM
CivicRaping's Avatar
Default how much can i lower a rsx without a camber kit?
Old 02-24-2005, 11:43 AM
jspec rsx's Avatar
an inch anything more you'll need camber kits in the rear ..... if you go 1.5 you'll only need the kits for the rear, I have 1.5 all around and the front is off just a tad bit doesn't wear out the tires at all.
Old 02-24-2005, 02:40 PM
Boosted RSX-S's Avatar
Default Re: (jspec rsx)
mine is 1.9" all around...been dropped for about 8 or 10 months or so, no problem with bad camber. i just rotated my tires a few days ago and the insides and outsides are wearing evenly. im sure a camber kit wont hurt though
Old 02-25-2005, 09:42 AM
krystar's Avatar
boosted....did u get an alignment? cause at 1.5 drop, my alignment spec sheet was at rear -1.6 and -1.7 camber and toe was fucked up. yer probably wearing your tires out if you didn't get a toe alignment.
Old 02-25-2005, 06:15 PM
blk02ep3's Avatar
Default Re: (krystar)
just drop it 4 inches youll be fine
Old 02-25-2005, 07:29 PM
PhunDrm's Avatar
I dropped mine way low. I just don't care about my tires.
Old 02-27-2005, 05:14 PM
LordAccord's Avatar
Default Re: how much can i lower a rsx without a camber kit? (CivicRaping)
People seem to think there's a magic number. There is not.
Do your drop, get an alignment, then you'll know. It depends on way more than just what model car you have.
Old 02-28-2005, 03:12 PM
TegSE's Avatar
How far and still be in factory spec.. or before you NEED a camber kit for appearance, handling or to avoid uneven tire wear?
Old 03-10-2005, 09:50 AM
integraautox's Avatar
Default Re: how much can i lower a rsx without a camber kit? (TegSE)
Im lowered with tein s tech springs and have no problems with my tire wear. I forget how much of a drop it is but it's pretty low and rides great.
Old 03-10-2005, 10:13 AM
Ares_ice's Avatar
tein s techs i believe are 1.7f 1.3r they look alright with an alignment camber correction isnt really necessary
Old 03-10-2005, 11:29 AM
DC5ITR329's Avatar
since we have macpherson design on the front any amount you lower it will change the characteristic of it so you would need an alignment unless you got a shock or coilover that was adjusted for the drop. like mugen ss.
Old 03-10-2005, 12:49 PM
whiteDCfiver's Avatar
Default Re: (Ares_ice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ares_ice &raquo;</TD></TR><TR><TD CLASS="quote">tein s techs i believe are 1.7f 1.3r they look alright with an alignment camber correction isnt really necessary
1.7F, 1.4R
I love mine. No probs with camber. Although a nasty pothole fucked up my alignment bad
Old 03-10-2005, 05:51 PM
aspec04t's Avatar
Lower it all the way to the ground Probably pretty low however you have to check the tire wear
98GSRDC2
Suspension & Brakes
08-17-2007 11:10 AM
E36 Guy
16
04-07-2006 09:58 AM
sslude
05-27-2003 10:36 AM
Screamer
10-11-2002 12:18 PM
InfamousRS
02-14-2002 07:31 AM
Quick Reply: how much can i lower a rsx without a camber kit?
