2006 honda civic
replaced compressor - condensor --- refilled system --- everything works perfect ... stopped the car ... when re-starting no ac ... the only way it starts if i reset the a/c control .... and no codes present in the control ... stop the car ... after 10 minutes or so if i dont reset the control ... a/c doesnt work .... do you have an idea ...
the compressor or the fan on the engine does not start ... all lights and control ... heat ... all works ... it seems to loose its memory ... after a certain time ... replaced the control and was ok for a few days ... started up again ... reset the control and ok ... now sometimes the ac wont start ... cycle the switch on and of 2-3 times and the engine fans start and ac is running .... i am wondering if the voltage drops maybe just enough to make the memory loss but not enough to cause any other problems ... any ideas ???
